Headlight gear issue worse?
Old Oct 24, 2006 | 04:05 PM
JetJazz's Avatar
JetJazz
Default Headlight gear issue worse?
Hi guys!
I just replace the motor gear in my 2000 vette headlight (it's the sealed type) and I failed to do this procedure:
BEFORE you remove the drive shaft and plastic gear, make a reference mark on the drive shaft and the housing
How bad is this and what do I do now? The glue has to cure for 24hrs so that's where I am now. I have not yet put the motor back on assembly.
Thanks for helping the mechanically challenged!
Old Oct 24, 2006 | 04:24 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
well....you can reinstall it and try it...if it works you got lucky...if not take the nut off the arm that raises the lights and try to rotate the gear and reinstall ...repeat until it works...PITA....
just a guess..
Old Oct 24, 2006 | 04:40 PM
JetJazz's Avatar
JetJazz
i got it worked out! No problem. Whewwww!
To Headlight gear issue worse?
