Hardcore Engine Crazies : EVAP removal Inside
Old Oct 24, 2006 | 07:53 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Default Hardcore Engine Crazies : EVAP removal Inside
OK, OK, OK - I admit I have "issues".
So while I have my car stripped bare, drivetrain and fuel tanks removed, blah blah blah - I wondered what I would have to do to remove the whole EVAP system.
Just wondering if any of you hardcore crazies have done this - and if yes, what should I look out for?
Anyone?
EG
Old Oct 24, 2006 | 07:59 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
*runs before the treehuggers arrive*
Ok, serously...what would be the benefit in doing so?
Old Oct 24, 2006 | 08:27 PM
0EG@EnglandGreen
Supporting Tuner
Weight. Complexity. Getting rid of unused junk.
Just like dumping the airpump, etc.
The EVAP system is HUGE.
Old Oct 24, 2006 | 08:53 PM
see5's Avatar
see5
I have not done it yet but have investigated and it looks like an easy patch. There are a few settings to zero out B0501-04.
Old Oct 24, 2006 | 09:05 PM
0EG@EnglandGreen
Supporting Tuner
Here is a schematic of the EVAP system
Old Oct 24, 2006 | 10:08 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Cleans up the compartment big time! I simply forgot to do it while doing my pull. It is nothing to edit it out but it looks a lot better!
Old Oct 24, 2006 | 10:16 PM
0EG@EnglandGreen
Supporting Tuner
Engine compartment and I want to get rid of the monster cannister behind the passenger fuel tank and all the lines under the car
Zero performance benefits, BTW.
Old Oct 24, 2006 | 10:19 PM
Cajundude's Avatar
Cajundude
The one single place I have not ventured to on my car yet. Gonna have to do it now.
Old Oct 24, 2006 | 10:21 PM
0EG@EnglandGreen
Supporting Tuner
Jason, I'll take lots of pics tomorrow when I remove the system
Old Oct 30, 2006 | 03:13 PM
slopokegtp's Avatar
slopokegtp
Old Oct 30, 2006 | 03:45 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Ya think?
Old Oct 30, 2006 | 08:54 PM
turboed's Avatar
turboed
now that we are on the subject of killing trees,has anyone removed the air pump sytem?i'm wondering what i need to plug and where?i just ordered lg streets with no smog pump fittings.
Old Oct 30, 2006 | 08:56 PM
turboed's Avatar
turboed
i wouldn't mind removing the evap crap either,is just more stuff to throw cel lights.
Old Oct 31, 2006 | 09:56 AM
kromberg's Avatar
kromberg
Talk like that will hurt the EPA's feelings
Keith
Old Oct 31, 2006 | 10:13 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Stephen I'd love to see the pics etc... I didn't even know where all that stuff was hiding. Please document as you remove.
Originally Posted by from my big mod project
More work done today...
Project 2: Removal of the stupid AIR system
Today after work I started removing the AIR pump and assorted hosing. I blew an AIR tube off at VIR and have decided to ditch the entire system. With the front bumper off the car it's the perfect time to do it.
Here's the AIR pump assembly... if you don't know, this pumps fresh air into the exhaust system at startup to help the cats work quicker for cold start emissions... that's all!
Here's the AIR pump intake... when you use a Vortex intake they give you this little filter to put on it.
Remove the plug
Remove the vaccum hose... I'll hvae to cap this later.
Here's most of the stupid system out... I hit a snag... I'll explain below.
As smooth as yesterday's work went I jinxed myself today... 2 things. First, I was removing the driver's side valve cover and my 8mm socket fell of and lodged itself on the front sub-frame under the powersteering rack!!! Took me an hour of fishing to get it out. Second, there is a bolt on the backside of the driver's side head that holds the last part of the AIR system on. You're supposed to just loosen it and slide the sutff out. Well I tried for an hour to get it loose but it was so tight I couldn't get enough leverage. I'll be pulling the intake manifold tomorrow to get better access to it.
Passenger side coil packs removd... one stupid part of AIR left!
Last bit of the stupid AIR system out!!!!
As for the vaccum line and plug... I just got an vaccum cap from my assorted kit, capped the line that runs to the pump, then wrapped it all in electrical tape and zip tied it secure to the frame.
Old Oct 31, 2006 | 10:27 AM
HP_Addict's Avatar
HP_Addict
I would like to remove my EVAP system too. If it does not make the car faster, remove it. Please do a how-to. What are the cons of removing it? Increased fuel odor possibly?
Old Oct 31, 2006 | 11:08 AM
kromberg's Avatar
kromberg
Biggest con is that codes will have to be disabled and you will not pass emissions. And yes, there will be increased fuel order.
Keith
To Hardcore Engine Crazies : EVAP removal Inside
Old Nov 20, 2006 | 12:49 AM
Xantium's Avatar
Xantium
Any ides on what to use instead of the evap system? Just a tank vent?
Old Nov 30, 2006 | 03:18 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
So how is this project coming along EG???? Did you end up doing a direct vent? Please update us....
Old Jan 27, 2007 | 07:28 PM
5W0P3's Avatar
5W0P3
subscribing
