Need Help (Indy)...Rear Control Arm Ball Joint
I need some advice to get this job done in a timely manner:
1) I would love to get my hands on the Kent Moore tool (part #: J-42188-1) that the dealership supposedly uses. I know a few guys have it, and if anyone would be willing to rent it to me or point me to one cheaper than the ~$180 I might even purchase it.
2) Per Jake Latham's C5 site (an excellent resource BTW) he was able to do this with a standard fork, but after a few jabs I'm getting nervous that I might damage something and could use some more detailed help if anyone else has taken this part off with a control arm fork:
http://www.jakelatham.com/c5/misc/
See step #14 under rear wheel bearing writeup to see where I am currently stuck.
3) I've read LG's writeup that you can drill the parking brake plate, but others haven't been able to reproce his results and I'm not a big fan of drilling that area.
So those are my options (sorted by preference) to get the job done.
...any help would be greatly appreciated!!
If so I used a rubber mallet and a 2 x 4. I put 2 x 4 over the bolt and wacked it with a rubber mallet. It popped out in a couple of blows.
I'm located at in the Meridian-Kessler area, just off N Meridian around 61st..
I'm trying to separate the lower control arm ball joint from the spindle...I hope I have that straight. It's step 14 of the Jake Latham link above.
I don't think a 2x4 would fit in there. I imagine you're taking about removing the tie rod, which I was able to do.
Thanks for the replies! I hope the car isn't down too long messing with all this.
Good luck!
I did the same thing to mine when I put in the chrome moly studs from DRM. They came right off with a couple of whacks.http://da.harborfreight.com/cpisearc...ord=ball+joint
- You don't need the Kent Moore tool
- The standard fork puller on Jake Latham's site is probably a bad idea...you'll either scar the aluminum or break the grease fitting open.
- A good old 2x4 and heavy 3lb hammer worked after several blows. there was no damage to the suspension anywhere.
It really helps to use a jack and lift the suspension up at the parking brake to get the leaf spring to help you with the hammer. Some of the bolts in the area are also easier to remove with the suspension jacked up a few inches.
I also didn't find that you needed to pry the ball joint back on as noted in Latham's site. Just get a wrench in and it all toqued down without drama. You will need to use an allen wrench to hold the tie rods in when torquing them.
Just happened to visit CF for the first time since about March or so, thought I'd chime in. (you know, now that it doesn't matter anymore
)I'll add those bits and pieces to the word docs that I have on the ol' site - I'm glad they've been so much help.
In terms of the pickle fork (aka "fork puller"), I recall that the orientation of the forks mattered as to whether or not I nuked the boot when trying to pop the knuckle off of the lower control arm. Time has clouded what that orientation was, though. I don't recall where I found the replacement boots either - I think perhaps a friendly Chevy tech pulled them off of some stock arms for me as a favor.
Glad you got the project done, and sorry for the delay replying - I didn't get any IM notification from the PM you sent...
Cheers!
-Jake
(jake.latham@gmail.com)
That pickle fork just made me very nervous since most any pressure would be exerted on either an aluminum suspension point or difficult to replace grease fitting. I probably didn't get the orientation right, but it sure wasn't for a lack of trying.
