slightly rough at idle, need help
My car a long time ago was doing that. Eventually the MAF went bad. Be very careful when cleaning the MAF, if I remember don't touch the connectors where there is some grease or vasaline stuff. That will damage your MAF for sure.
Cheers!!
Cheers!!
I do have HP tuners for the vett. I'd rather leave it stock till I get som other things put on the car.
What about a fuel filter?
What about having the fuel system cleaned? Or can i put in some fuel additive/cleaner from a bottle.
Any other suggestions that I can do or look at?
Cheers!!
Since then, I have ported the throttle body, ported the MAF, done the coolant bypass, Blackwing, long tube headers, cat removal, x-pipe, corsa pro series, TR 55 plugs, MSD 8.5 wires, and had about 5 reflashes (tunes). After porting the thottle body and the Blackwing (did them at the same time), the idle problem got a little better. I could still feel it, just not as bad.
After the header, exhuast install I went to get my first street tune (the first few were just generic tunes, as I told my tuner I would be installing headers). I had some knock retard in the 4800 to 5200 rpm range. After a little deducing, we attributed this to carbon since my miles were mostly highway (low rpm). We also thought this might fix the idle.
After the Seafoam, I took it back again and now the carbon removal has caused the passenger 02 sensor to go bad. I put a new 02 sensor in it and when I drove it, the idle problem had gotten worse, back to like it was when I bought it. It's kind of embarrassing when everyone asks you why it idles like that. My 65 year old mother even noticed.
This is where I am right now. If this rain outside will subside I am going back to the tuner today and try to get a decent tune in it. We have talked about the idle, but these other problems have overridden the idle thing for now.
I'll post up when I have something to add.
VR
VR
Like I said above, my timing was at 28 degrees at idle, so someone has been in the PCM at some point. I am wondering now, if maybe it had a cam in it at one time and he took it out when he bought his new car. All I know about the previous owner is, he was the nephew of the owner of the dealership and he traded this car on a new C-6. I assume the same cam for a LS1 will fit a LS2. I think it's time to invest in some tuning software and just see for myself what is going on in there.
