Advise On Jack & Jackstands
Old Oct 25, 2006 | 09:05 PM
aschiftner's Avatar
aschiftner
Default Advise On Jack & Jackstands
A couple questions before I buy a jack and stands.....
Is there a specfic jack that is low enough to lift my stock height coupe without having to drive up onto something?
Any specific jack / jackstands you recommend or features would be appreciated.
Thanks Al
Old Oct 25, 2006 | 10:03 PM
Illini82's Avatar
Illini82
St. Jude Donor '07
I just picked up a set of stands from the local Harbor Fright store for about $25. They are 6 ton and are more than solid enough for working on the Vette.
As for a jack, I'm also looking and would like to hear what others have to say
Old Oct 25, 2006 | 10:32 PM
Dave Witman's Avatar
Dave Witman
I have a sears craftsman aluminum jack that works great. And no I don't own a miata. Dave
http://mymiata.paladinmicro.com/MiataCRALJack.htm
Old Oct 25, 2006 | 10:40 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
Can you slide this jack under the front of the car and lift under the crosssmember without driving up on boards? Thanks, Greorge
Old Oct 25, 2006 | 10:49 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
yes, but I usually drive up on 2x6's to avoid marking up the plastic deflector
Old Oct 25, 2006 | 11:02 PM
Dave Witman
Yes I think so but will double check tommorrow and send you a pm with the jack part number. Did you try a search because I purchased mine from advice from this forum. Dave
Old Oct 25, 2006 | 11:26 PM
aschiftner's Avatar
aschiftner
I plan on lifting from the crossmembers as well.
I'm not sure but I thought that driving up on ramps would / could get in the way because I want to use the pucks in the frame method.
Looking for jackstands that mate well with the pucks.
I read something about a Craftsman low-profile jack awhile back. Thanks Al
Old Oct 26, 2006 | 02:27 AM
10VETTEMAN's Avatar
10VETTEMAN
I Just Bought A Low Profile 1 Pump Set Jack From Mac Tools For About 250 Will Reach Rear Diff Or Front Crossmember With No Probs
To Advise On Jack & Jackstands
