fog lights
Old Oct 27, 2006 | 07:51 AM
kg54trains's Avatar
kg54trains
Default fog lights
had to replace BCM, which had everything working again but suddenly the fog switch and lights do not work. The littile light on the switch is not on and fog lights are not working. Checked fuse not blown. Car 1998 Coupe.
Thanks for the help
Old Oct 29, 2006 | 12:35 PM
larrymcgraw's Avatar
larrymcgraw
Did you happen to find a fix for your fog light problem? Note the thread I posted today "C5 fog lamp malfunction." Thanks!!!
Old Oct 31, 2006 | 10:06 AM
SilvaDragon's Avatar
SilvaDragon
Thanks for the help
Did you check for codes? There are BCM codes associated with
fog light failure.
Failing that, you might need someone with a Tech2 to "turn on"
the option in the computer for you. (i.e. the car may no longer
realize that it has fog lights, as odd as that may seem).
To fog lights
