last night a buddy and i hollowed my cats out and bolted them back up in with band clamps.
it wasnt a much louder sound and the CEL has yet to come on.. but i also do feel an increased throttle responce.. any idea what the problem is? a leak in the connection maybe?
also im noticing that the tail pipes are extremely warm, i think that is a side effect of the cats being taken off..
change front o2 sensors, hotter than normal tailpipes can be a lean condition and you not gettting a cel show they do not have an accurate reading to begin with. and get sims for the rear they are only like 20 dollars.
thanks for your input guys!
Gutted mine... I wish I did not.. All I got was louder which was what I was looking for..
What I did not want was STINK! My garage smells and my clothes smell of fuel.. Worse in the summer..
Trust me.. the CEL WILL come on.. takes some time..
where can i get the rear sims at?.. i have some sims coming already from someone off the forum.. 20$?? where at dude?
you can buy sims from any auction site for about $20, the fit any gm car, however they are not plug and play like the good ones, you have to hard wire them in, 3 wires not a big deal at all and not like anybodys gonna see them. If your exhaust really is alot hotter than before, like headers glowing red then you could burn it up.
oh no headers wernt glowin or ne thing from what i saw, but i did notice the tail pipes were hot to the touch.. someone said that larger injectors would make the car run less lean
Don't go replacing injectors and other parts until you figure out the problem. Unless you're heavily modded you don't need bigger injectors.
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Drive it a while. It will take some time for the computer to learn the new Air/Fuel ratio. One of two things is going to happen. The computer will adjust to the ideal parameters, or a code is going to be thrown. WOT is probably off also now. You really probably should get it tuned. Also, if you didn't disable the rear O2's, you'll get a code.
I personally would never gut the cats. But that's just me. As chuckster pointed out, the stink can be pretty bad.
Minor correction.. Gutting the Cats has nothing to do with the A/F.. There are 2 sets of O2's
the first set right off the exhaust manifold are there to measure A/F and the computer adjusts there..
The 2nd set are located AFTER the cats...and they simply monitor the A/F in regards to emmissions.. too much emission sets a Cel...That is it..The computer could care less what happens...
In fact you can drive around forever with the CeL lit and the worst thing that can happen is you will fail inspection.. if you have that in your state..
correction, If you gut the cats and the exhaust flows better and scavenges better there is going to be more air in the combustion chamber and therefore will require more fuel. It will obviously affect the a/f ratio. Next rear 02 sensors do not monitor emissions. And you wont get a code because of high emissions. The computer uses the rear 02 sensors to verify that there is an oxidation reaction taking place inside the cats, by the lack of oxygen in exhaust after cats. The computer will allow the engine to run lean if it thinks that there is not enough oxygen for oxidation reaction. . hence hotter than normal exhaust. Obviously they did put some thought into this though and there is limitations on what it will allow the a/f to be. You wont be able to seize a motor because of a bad 02 sensor.
Flowing better has been a big debate.. 2-5hp.. on 350hp the computer would certainly adjust but would be minimal at best..
And you are correct as far as it not measuring EMMISSIONS specifically.. I realize that but was trying to keep the explanation simple.. The poitn I was trying to make is that the rears have zero to do with the PCM and A/F
Thats odd, if anything your exhaust should have been hotter with working cats. A working catalyst generates alot of heat.
Not true. A Working catalytic generates INTERNAL heat needed for its own working condition, However since it is INDEED an exhaust restriction, slower mooving exhaust gas that has moved out of the cat, into the cooler exhaust will get a better transfer of heat from the exhaust pipe itself. Now that the cats have been removed, you have free flowing exhaust which will now have constant heat moving over it, which in turn will increase the surface temp.
Florida does not...
hey dwarmenzerk,i see you're in cape coral,i'm in miami and i can shut down your rear o2's so you don't get a cel light and even lower your fan temps for a 160 thermostat if you haven't done that yet,i can also see if you ecm is pulling timing and do some data log,i have a scanmaster and also hp tuners pro,pm me if interested.
