Oil Presure?
Old Sep 19, 2001 | 09:13 AM
C6VETTE4FUN's Avatar
C6VETTE4FUN
Default Oil Presure?
What is the normal reading for oil presure on the analog gauge in dash?
I believe my gauge is bad, but digital reads 125? (must be shot)Going into shop tomorrow..any ideas if this is the sensor for oil or sending unit?
Old Sep 19, 2001 | 09:30 AM
TLewis4095's Avatar
TLewis4095
Default Re: Oil Presure? (1997C5VTBOY)
Í'd bet sending unit....
Old Sep 19, 2001 | 12:25 PM
motoracer's Avatar
motoracer
I am having the same problem with my car. I just had the computer replaced, last week hoping that it would fix the problem. But replacing the computer (PCM) fixed all the other problems (RTD and Traction control was out). So mine must be the oil sensor. The problem with that is that its a behind the intake and I was quoted $500 in just labor to replace the $70 part. The intake has to be removed to get to the part.
The sensor is behind the intake on the top of the engine. You may want to check to see if the connection came loose. Most likely not a loose connection, but you never know.
Hope this helps and post your results, I am curious as well. I was planning on replacing the part later myself.
Old Sep 19, 2001 | 12:50 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
I can tell you this..... it isnt 125 psi
Old Sep 19, 2001 | 02:34 PM
C6VETTE4FUN
Default Re: Oil Presure? (motoracer)
thanks..I will let you know the results tomorrow..
To Oil Presure?
