tire sensor dic display
Old Oct 28, 2006 | 04:27 PM
Zoso1951's Avatar
Zoso1951
St. Jude Donor '05-'07-'08-'09
Default tire sensor dic display
Isn't it possible to disable the dic warning if you remove your tire sensors? Does any one know the right code to disable the warning???
thank you!
Old Oct 28, 2006 | 04:37 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
you will have to delet the RPO code in the BCM and only someone with a tech II can do this.
Old Oct 28, 2006 | 04:53 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
thank you!
You can not do it with your 99 C5, this only became an option in 2001. even with a Tech II there is no option.
Old Oct 28, 2006 | 07:15 PM
99 vett babycar's Avatar
99 vett babycar
To tire sensor dic display
