Checking Codes with Engine running
Old Oct 29, 2006 | 04:43 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Default Checking Codes with Engine running
Hi All, This may or may not be of interest to any of you but you can check your engine codes with the motor running. I discovered this while sitting at a red light telling a passenger about the codes… “Yeah, you just hold this button and push this one four times and all the trouble codes start cycling”…. And they did! I am getting an occasional TCS C1276 H after my CAI and cat-back install and checked the codes right after a burnout, then after a WOT 1st to 2nd and again after a WOT 2nd to 3rd. Anyway, long story short is that I only throw a C1276 when shifting gears not a burnout.
Tim
99 Coupe
