Lean Cruise
Old Oct 29, 2006 | 08:50 AM
tarheeljww's Avatar
tarheeljww
Default Lean Cruise
Goodmorning,
Does anybody know what this is and can it be added to a C5?
I posted this question on the Tune page but only got one response, so asking it here, and there is nothing in the search either.
The GTOs have the capability to add this as they have it in Europe and I have seen claims of 500+ hp and 32 mpg with the Lean Cruise added to the tune.
Curious minds want to know......
Thanks,
Jw
Old Oct 30, 2006 | 11:50 AM
brentg454's Avatar
brentg454
From everything I have seen and read, Lean Cruise is only enabled on GM export cars and Holdens, Opels, etc. It's there in the menu tree on EFILive just taunting you, but you can't turn it on.
Brent
Old Oct 30, 2006 | 08:14 PM
tarheeljww's Avatar
tarheeljww
Thanks, thats what I wanted to know. I have been told it was there, and wondered if anybody has or can turn it on.
Wonder why the Feds don't want it. One opinion is, too much emissions.
Thanks again.
Jw
Old Oct 30, 2006 | 11:35 PM
boosted_z06's Avatar
boosted_z06
It is illegal in the USA as to EPA rules and you cannot simply turn it on since GM has a jump routine in the PCM software on American cars so it is not used.
Old Oct 31, 2006 | 11:16 AM
muncie21's Avatar
muncie21
Yup
Old Oct 31, 2006 | 01:22 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Originally Posted by tarheeljww
Goodmorning,
Thanks,
Jw
GMPX (a god of EFILive ) has spoken on this subject. Here's a link-> http://forum.efilive.com/showthread.php?t=833
Old Oct 31, 2006 | 02:42 PM
Billdog350's Avatar
Billdog350
I thought your O2's aim for a "lean cruise" by default when you're in closed loop and crusing along at part throttle? At WOT you go to 12-13:1....otherwise its running at 14-18:1
Are you saying they run it even leaner than that? Regardless, we're getting close to 30mpg on the highway for most people...why mess with it? Want to give a corolla a run for its money?
Old Oct 31, 2006 | 03:58 PM
minytrker's Avatar
minytrker
You can do lean cruise with a custom operating system with efi live. I tried it on my z06 with h/c and bolts ons and didnt see a big increase so I went back to 14.68 at cruise and still get 30+mpg with 400+rwhp.
Old Oct 31, 2006 | 04:12 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Good info
Old Oct 31, 2006 | 06:26 PM
muncie21's Avatar
muncie21
US cars shoot for an AFR ration of ~14.6:1. Under light load (cruise) your engine can safely run leaner. AFRs of ~17:1 are used in other parts of the world. 14.6 isn't a magical number, is just happens to be chemically correct and produces the least amount of by-products when used in conjunction with a cat.
Old Oct 31, 2006 | 10:47 PM
Humanoid 2.0
14.7:1 is the stoichiometric ratio, which is the theoretical ratio to completely burn the available fuel.
To Lean Cruise
