Which Thermostat
Old Oct 29, 2006 | 10:38 PM
SunDevil C5's Avatar
SunDevil C5
Default Which Thermostat
I live in AZ so cold starts and heat isn't really an issue. What temperature would be a good choice for a thermostat.
Old Oct 30, 2006 | 01:31 AM
Bill Dearborn's Avatar
Bill Dearborn
The stock thermo is good anywhere in the country. The engine will operate at a proper temp with the stock thermo. There is nothing to be gained by switching to a lower thermo.
Bill
Old Oct 30, 2006 | 01:36 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
I run the 160 in my vette and TA
Old Oct 30, 2006 | 08:59 AM
6Speeder's Avatar
6Speeder
Go with the Hypertech 160 and reset the fan temps.
Old Oct 30, 2006 | 09:51 AM
kevin40zx's Avatar
kevin40zx
I just got the 178 deg., the car's temp stays around 187 while driving but still skyrockets to up around 220 when you sit still.
Old Oct 30, 2006 | 10:20 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
170 in mine w/ the fan temps set at a low come on point! I live in the desert in California and this seems to be a great combo for my '98 Vette!
Thanks,Matt
Old Oct 30, 2006 | 11:33 AM
99 vett babycar's Avatar
99 vett babycar
what you have is perfect
Old Oct 30, 2006 | 02:35 PM
SLPRC5's Avatar
SLPRC5
Over the past weekend I went from a 180 back to my 160. Car ran like crap with the 180. Maybe because it was tuned with a 160. Anyway a 160 or 170 with fan settings should do you fine. IMHO
Old Nov 3, 2006 | 11:11 AM
Vetteoholic's Avatar
Vetteoholic
I personally have a 160*Thermostat, It's good to have & works well, but the fan Is always coming on about every 2 mins. Even In the winter!!
Old Nov 3, 2006 | 01:11 PM
MGorman's Avatar
MGorman
Bill
I’m not sure I understand this statement. My car runs consistently quicker and faster at the drag strip with a low temp thermostat and coolant temperatures 178-180 degrees as opposed to 192-195 degrees with the stock thermostat
Old Nov 3, 2006 | 01:52 PM
Patman's Avatar
Patman
The LS1 does not run it's best quarter times when the coolant temp is hotter, it likes 180-190F.
Old Nov 3, 2006 | 02:07 PM
SLPRC5's Avatar
SLPRC5
Old Nov 3, 2006 | 02:08 PM
SLPRC5's Avatar
SLPRC5
Have your fans set, that should cure it.
To Which Thermostat
