Torque spec on caliper bolt?
Old Oct 31, 2006 | 08:21 PM
Z06Modder's Avatar
Z06Modder
Default Torque spec on caliper bolt?
Very strange thing happened to me yesterday driving home. Heard a thump-thump-thump. Pulled the car over and noted that the wheel weights mounted on the inside of my rim were getting worn down by my caliper!
Took the wheel off today and the top bolt fell out of my caliper!!?
Luckily no serious damage done to the inside of the wheel or the caliper that I can tell. Located a bolt at Advance Auto Parts (comes in a hardware kit), but was wondering if anyone knew the torque spec for this bolt that holds the caliper to the bracket?
TIA
Old Oct 31, 2006 | 08:42 PM
UVETTYA's Avatar
UVETTYA
Brakes
Caliper Bleed Screw 12 N·m 106 lb in
Guide Pin Bolt 31 N·m 23 lb ft
Caliper Inlet Fitting Bolt 40 N·m 30 lb ft
Mounting Bracket Bolt 175 N·m 125 lb ft
No charge.
Old Oct 31, 2006 | 08:50 PM
Z06Modder's Avatar
Z06Modder
Default Re:
Thank you sir!
SLPRC5's Avatar
SLPRC5
Also at no charge.....
http://eliteengineeringusa.com/C5_Torque_Values.pdf
Old Oct 31, 2006 | 11:24 PM
FrogmanDave's Avatar
FrogmanDave
Don't forget the Loctite
Old Nov 1, 2006 | 02:31 PM
Z06Modder's Avatar
Z06Modder
Default Re:
The hardware kit included loctite on the bolts!
To Torque spec on caliper bolt?
