Engine oil pressure sensor!
Old Nov 1, 2006 | 10:59 AM
harleyvette's Avatar
harleyvette
Default Engine oil pressure sensor!
I have been trying to find a good sensor other than stock.
Some say get brass. I cannot seem to find any where I live.
Could anyone give suggestions? and where to get it.
I can go to any place in the Detriot Michigan area.
THANKS
Old Nov 1, 2006 | 01:13 PM
2kbluestreak's Avatar
2kbluestreak
Noble quest. There have been reports here of Mr. Goodwrench replacing failed OP senders only to have the replacements fail in a couple months. Replacement Crap = Originally Supplied Crap: why not? There's a little bit of labor involved, which means it takes time for the do-it-yourselfer or $$ to Mr. Goodwrench if the car's out of warranty, so finding a more reliable sender is a good idea. To remove the old and install a new sender, you'll need a large socket, something like 1 1/16 to 1 3/16, can't remember which.
Old Nov 1, 2006 | 01:27 PM
berryj's Avatar
berryj
Here's a link to take care of this:
http://forums.corvetteforum.com/show....php?t=1472249
In that link you'll find a link also to Vector Z's write up w/ pics in addition to my addendum to his write up to help.
Many have said the best replacement was found from Rockauto.com.
Hope that helps
Old Nov 1, 2006 | 01:34 PM
MrPickles's Avatar
0MrPickles
Former Vendor
gmpartsdirect.com
Old Nov 1, 2006 | 01:45 PM
MattB's Avatar
MattB
Borg-warner, mines been going only a few months but that is a lot longer than the delco unit did.
Old Nov 1, 2006 | 03:53 PM
David426's Avatar
David426
Stay away from the GM Delco Made in Mexico brand... Napa Auto Parts is where to go. $$$ Cheaper too
Old Nov 1, 2006 | 06:27 PM
77BlueL82's Avatar
77BlueL82
Default Just did mine.
this weekend. I used The Standard Ignition replacement. Use Victorz write up. Job took about 2 hours.
Old Nov 1, 2006 | 07:52 PM
LoneStarFRC's Avatar
LoneStarFRC
www.rockauto.com PS-308 Mine is about 3 years old now and no more leak.
From past experience with some of NAPA's parts, or Borg-Warner's parts, I'm sure they would be a good alternative as well.
To Engine oil pressure sensor!
