Check Engine Light On - O2 Sensor codes
Old Nov 2, 2006 | 04:32 PM
vetpet's Avatar
vetpet
Default Check Engine Light On - O2 Sensor codes
I need some help with diagnostics for the following O2 sensor codes. All four of my sensors seem to be acting up at the same time. Here's a screen shot from my scan tool.
Thanks.
Old Nov 2, 2006 | 07:45 PM
vetpet's Avatar
vetpet
Can anyone help me out?
Old Nov 2, 2006 | 08:58 PM
vetpet's Avatar
vetpet
Hello...anybody home?
Old Nov 2, 2006 | 09:07 PM
SLPRC5's Avatar
SLPRC5
Replace them or turn them off with a tunning software
Old Nov 2, 2006 | 10:52 PM
JVetthead's Avatar
JVetthead
I had the same problem...CK fuse in under-hood fuse center..I forget witch one it is but its there...
-Joe
Old Nov 3, 2006 | 02:38 PM
vetpet's Avatar
vetpet
Thanks Kindly for the help Vettehead. I'll have a look.
Old Nov 4, 2006 | 08:48 PM
vetpet's Avatar
vetpet
Checked fuse and it was blown. Replaced it, cleared the codes and then took car for a good drive. Check engine light has not come back on. Thanks JVettehead for the help. Just goes to show you that you should always think of the simple things first.
Old Nov 4, 2006 | 09:52 PM
dwarmenzerk's Avatar
dwarmenzerk
yeah i understand that..
one day my tranny was shifting super hard.. and it is at the stock pressure..
i was flipping out..
then i had a CEL come on.. then replaced intake air temperature sensor since then the tranny has been beauitful!
(A4)
To Check Engine Light On - O2 Sensor codes
