transaxle removal
Old Nov 5, 2006 | 04:04 AM
Aussie C5's Avatar
Aussie C5
Default transaxle removal
Hi, would anyone know of a site, that shows how to remove or lower the transaxle as i've got a fuel leak at crossover and need to lower transaxle. Any info would help an aussie
Old Nov 5, 2006 | 04:08 AM
EHS's Avatar
EHS
This do it for you, mate?
http://www.corvettefever.com/howto/18978/
Crikey, that was fast....
Old Nov 5, 2006 | 08:13 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
when you drop the rear xmember pay attention to the items that will be affected up front, ie. intake, aft fuel rail to firewall clearance
Old Nov 5, 2006 | 03:19 PM
Aussie C5's Avatar
Aussie C5
Thanks heaps mateys for the reply on the how-to site and it makes good sense on possible up front damages that can happen. You know you yankies are all right down here. Better go, got to feed the kangaroos and stingrays in the pool
Old Nov 5, 2006 | 05:36 PM
VLVETTE's Avatar
VLVETTE
Look up Mercury Mike he has a step by step for dropping the whole rearend
Old Nov 6, 2006 | 10:12 AM
kromberg's Avatar
kromberg
A jack stand right under the bellhousing will prevent the motor from tipping back and causing those problems Place the jack stand first before removing the torque tube.
Keith
Old Oct 28, 2020 | 09:20 AM
Autoeng's Avatar
Autoeng
Found this link to the original how to
http://www.superchevy.com/how-to/18978
To transaxle removal
