Battery relocation?
Old Nov 6, 2006 | 11:01 AM
nuke61's Avatar
nuke61
Default Battery relocation?
Has anyone out there considered doing it, or has actually gone through with it? The only spot that looks like it could be done is with the center depression near the rear bumper (some of you may have your 6-CD changer there) since its large enough.
Old Nov 6, 2006 | 11:06 AM
W Muller's Avatar
W Muller
That's where My spare tire is.
Old Nov 6, 2006 | 11:42 AM
BlueThunder2000's Avatar
BlueThunder2000
Vettaholic
Nope. I relocated mine in the bin behind the passenger side rear wheel. It is big enough to house the battery and is closer to the rocker panel (where I routed the cables). Also better for mass balancing.
I manufactured a battery support tray using plywood, which I installed at the bottom of the bin. Then I built a restraining bracket out of aluminum, to keep the battery down there. That bracket attaches to the fasteners where the stoclk bin cover attaches to. Of course, I tossed that cover, because anyway I am redesigning the entire trunk area.
Several people did this mod, you can certainly find some ideas by using the search function on "battery relocation".
Have fun
Old Nov 6, 2006 | 01:25 PM
nuke61's Avatar
nuke61
Cool... it didn't look like it would fit in that spot, but then again, I didn't measure either. I'll do the search for battery relocation. Thanks.
Old Nov 6, 2006 | 02:15 PM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
I just bought one from Thunder Racing and it goes on in a few weeks with a roll bar. We are putting it in the back, passenger side like mentioned before. I have heard that this mod helps like a 100 lb loss in a C5. Good luck!!!
Dave
Old Nov 6, 2006 | 03:38 PM
nuke61's Avatar
nuke61
It sounds like that's the place to put it, but doing a search of "battery relocation" in the C5 sections yielded no useful results. Ditto for "relocate battery" and "move battery", but in any case, the passenger side trunk pit is the spot.
Old Nov 6, 2006 | 03:52 PM
kromberg's Avatar
kromberg
Is the passenger side compartment really big enough to fit the battery and box? It just looks way too small to fit both.
Keith
Old Nov 6, 2006 | 04:01 PM
SpeedyZ's Avatar
SpeedyZ
What battery (type, brand and model, top or side post) are you guys using in the right rear compartment?
Does the battery, cables, and hold downs all fit below the top of the compartment so a lid can be used?
I'm wanting to do this but can't find a battery that fits in there good.
Old Nov 6, 2006 | 05:09 PM
bighank's Avatar
bighank
Default battery relocation
Guess you folks like LONG THICK BATTERY CABLES running to your trunk.
How about VOLTAGE DROP. Lets see how you like starting the cars in WINTER when its below zero. I had a chattering starter when I used some #2 cables when I had the battery out. I wouldn't recommend 10 or 12 foot long cables to the starter. Especially if you live in a cold climate.
Old Nov 6, 2006 | 05:38 PM
tlaselva's Avatar
tlaselva
Have the Lingenfelter Rear batter relocation kit.
Never had any issues starting, even in our cold Canadian winters.
Old Nov 6, 2006 | 05:41 PM
DidntSettle's Avatar
DidntSettle
From: Manchester - Political correctness is tyranny with manners.
Bighank is 'spot on' here. I guess my question is why would you want to do this? There are certainly no benifits as far as voltage is concerned because these cars already use all that is available. Why risk throwing codes or poor starter performance because your voltage is lower?
Old Nov 6, 2006 | 05:49 PM
tiojames's Avatar
tiojames
I doubt Bighank is "spot on" here. I have the batt. in the rear and it gets down to 15-17 degrees here in Flagstaff and I've never had any trouble. It amazes me how some of you give advice on something you have not done.
Old Nov 6, 2006 | 06:16 PM
hotwheels57's Avatar
hotwheels57
It all depends on your cable size (both positive and negative should be the same size) and care in mounting the ground(s).
I've run 20 ft. of #00 aircraft spec cable from the trunk to the front and never had any issues of hard starting in northern AZ weather, either. I used either the frame as the ground or run a separate ground cable to the front and both worked equally well.
I also use high CCA batteries (OPTIMA) and maintain them on a float maintenance charger for the months of winter (BATTERY TENDER PLUS @ 1.25 amp).
Old Nov 6, 2006 | 06:55 PM
chiefDave's Avatar
chiefDave
Thanks for the input. I think you will find that there is a very small drop in potential over large gauge cable in as short a cable as 10 to 12 feet. We all know the starter requires a great deal of current to turn over the motor, relative to small amunts of voltage (+12VDc).
The battery relocation mod is primarily done to move wieght from the front to the rear to help in drag racing and the launch. The reduction up front helps for a quicker transfer and a better launch. Anyone moving the battery to the rear will probably not be overly concerned about cold weather starts, as thier car proabaly does nt get much cold weather use as most track close when it gets realy chilly.
Back on the original post, you can find kits @ several sponsors on the let, like LPE and thunder racing. Good luck.
Dave
Old Nov 6, 2006 | 07:14 PM
SpeedyZ's Avatar
SpeedyZ
<snip> I guess my question is why would you want to do this? <snip>
To make room for a dry sump tank....
I would prefer not to go that far back myself. I would like to keep the weight in front of the rear wheels, but there is just no place else to put it if your going to haul a passenger.
Old Nov 6, 2006 | 07:20 PM
nuke61's Avatar
nuke61
I don't think cold weather starts are going to be a concern for me in Vista, Ca. Today, November 6th, it was 92F at my house, and 85 at the coast
Just use thick, high quality cables for positive and negative and the run won't be an issue. The reason I'm doing it is for weight distribution. I'll be putting on a supercharger next month, and although I know this won't balance out the SC weight, it will help.
Old Nov 7, 2006 | 01:00 PM
Vetteoholic's Avatar
Vetteoholic
If It can be done which I'm sure It can, there would be some benefits from doing so. First you would transfer about 60 or so Lbs to the rear wheels which also would get you closer to 50/50 weight.Dist. 2nd, the battery would be more protected In the trunk & would never get wet or anything. I'm gonna read more Into this for my car. Best of luck
To Battery relocation?
Old Nov 7, 2006 | 03:53 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Drag racers be aware if you relocate the battery to the rear NHRA and likely IHRA (don't have their rule book) requires an external on/off switch coming out the back of the car. So when you show up at the track if they make you open your hood you will be exposed
Old Nov 7, 2006 | 07:32 PM
auctiondepot's Avatar
auctiondepot
Last year I put the biggest battery that would fit in the passenger rear pocket and connect it to the existing pos cable with 00. then grounded to the adjacent frame and with 2 smaller cables up front.
The hardest part is attaching the battery to the frame as it is not directly underneath. You have to retain the existing heat shield.
I made the Al box for the battery
Old Nov 7, 2006 | 10:16 PM
Howard Wolf's Avatar
Howard Wolf
If you're relocating the battery to the back just for weight distribution and don't intend to use it at the dragstrip (NHRA), the small rear compartment on the passenger side works well.
If you plan to race, a covered housing is required with ventilation to the outside and a kill switch somewhere on the exterior of the rear panel, easily accessible by the crash crew, is mandatory. Lingenfelter has a complete kit for this application and I highly recommend it. It goes in the larger compartment in the rear. Quality, as with all their products, is outstanding.
