is 243 LS6 heads?
Old Nov 6, 2006 | 09:36 PM
htvette's Avatar
htvette
Default is 243 LS6 heads?
Thanks.
Old Nov 6, 2006 | 09:42 PM
vetpet's Avatar
vetpet
Yes, 243 is the casting# for the LS6 heads. You can see it stamped at the front of the passenger side head.
Old Nov 6, 2006 | 09:45 PM
ICaughtVetteFever's Avatar
ICaughtVetteFever
How do you tell what year head they are?
Old Nov 6, 2006 | 10:11 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
243 castings are used in '01-04 Z06's and the new LS2's
there are different valves used depending on year, IE: '02-'04 lightweight sodium filled valves
under the intake port on #1 or #8 cylinder there should be a year cast into the bottom of the head
you'll see some #'s next to the '243' marking near the valvecover ridge, if anyone has the breakdown on those let us know
To is 243 LS6 heads?
