Idler pulley
Old Nov 8, 2006 | 10:51 AM
rando's Avatar
rando
Default Idler pulley
I'm changing out the tensioner pulley on the main belt drive. In what direction does the screw loosen?
Old Nov 8, 2006 | 10:54 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Left... it's a 15mm socket. You turn it right to loosen belt tension and slip the belt off, then left to loosen the nut.
Old Nov 8, 2006 | 11:31 AM
tompugh's Avatar
tompugh
Yo, I need to change mine too (making the dreaded rattle noise). Do you have the GM part number for the pulley? Thanks, Tom
Old Nov 8, 2006 | 11:35 AM
rando's Avatar
rando
I called the dealer and they told me that the whole tensioner mechanism had to be replaced. Went to Advance Auto and bought the pulley for $20.00.
Old Nov 8, 2006 | 01:30 PM
tompugh's Avatar
tompugh
Yeah, I have heard the same thing. The complete assembly is like $80+. I have a PEP BOYS here. I will give them a try. Thanks, Tom
To Idler pulley
