Column Lock
Old Nov 8, 2006 | 03:32 PM
diverman's Avatar
diverman
Default Column Lock
The message "Service Column Lock" just appeared on the DIC on my 2000 convertable.I had the recall work done over a year ago.I did just have to have the ignition switch replaced,I'm wondering is it related to that.It's been less than 100 miles.Has anyone had this message appear on their vette?
Old Nov 8, 2006 | 03:34 PM
02gt350's Avatar
02gt350
Old Nov 8, 2006 | 03:41 PM
wamara's Avatar
wamara
Cruise-In II Veteran
Diverman,
First of all, check out the sticky thread on this problem.
Second, what transmission do you have? (It makes a difference).
Third, do you know exactly what work was done when they did the recall? (There have been a few versions).
Fourth, I doubt the ignition service had anything to do with it, unless they somehow bumped/damaged/whatever the wiring/harness that pertains to the column lock.
Good luck.
Ryan,
Patience grasshopper
Old Nov 8, 2006 | 03:46 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Originally Posted by 02gt350
Way to help him out.
Old Nov 8, 2006 | 03:58 PM
Blue02ws6's Avatar
Blue02ws6
That smilie is PERFECT for so many threads.
Old Nov 8, 2006 | 04:53 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Old Nov 8, 2006 | 05:51 PM
C5Jimmy's Avatar
C5Jimmy
Install or have installed the Column Lock Bypass. Available from Corvettes of Houston, $49.95
To Column Lock
