Turn it to the left to make it less stiff. There should be a + & - on the ****. The best thing about adjustable shocks is that you can change them whenever you want with the turn of a ****. Don't worry about getting them right the 1st time, just reach under and turn it a click or two. Assuming you have the single adjustables, turn the **** to the softeest setting(all the way to the left) and turn it 3 clicks to the right and if you want it a little stiffer go one more. It took me a couple of trys to get mine dialed in to where I like it
