removing wheel balance weights
Old Nov 9, 2006 | 10:23 PM
jo8243's Avatar
jo8243
Default removing wheel balance weights
what's the best way to remove the clip on/hammer on wheel balancing weights without damaging a wheel?
Old Nov 10, 2006 | 02:13 AM
jbauch357's Avatar
jbauch357
in a perfect world you would use this: http://www.perfectequipment.com/tools_71k.php
You may also be able to slip a small screw driver in behind the back side of the weight clip to pry it out and off the wheel. Alternatively you can protect the tips of needle nose vice grips with a rag and get a good bite on the top and bottom of the weight (make sure to grip on the center of the weight instead the outside or you will just be adding more clamping pressure to the weight clip).
The main thing to remember is that you need to pry the clip portion out and away from the wheel lip, not the weight portion up towards the tire.
