Does the Vette Need a Drive Shaft Loop?
Old Sep 21, 2001 | 12:43 PM
Als98C5's Avatar
Als98C5
Default Does the Vette Need a Drive Shaft Loop?
Last time out to the track the inspector in the tech section asked me if I had a drive shaft loop. I told him of course I do, but do I?
Old Sep 21, 2001 | 01:10 PM
gonbad's Avatar
gonbad
Default Re: Does the Vette Need a Drive Shaft Loop? (Als98C5)
If being technical? No you don't have a drive shaft loop. In fact you don't even have a drive shaft. You have a torque tube that is completely inclosed within a structural center tunnel of the car. Therefore it is impossible to drop the "shaft." :D
Old Sep 21, 2001 | 02:05 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: Does the Vette Need a Drive Shaft Loop? (gonbad)
Yea, what he said.. Correct.. :seeya
Old Sep 21, 2001 | 02:40 PM
Fahtrim's Avatar
Fahtrim
Default Re: Does the Vette Need a Drive Shaft Loop? (CHRIS NJ C5)
The inspector was either:
a. Pulling your leg and laughing at your answer.
b. Stupid
Old Sep 21, 2001 | 03:14 PM
Steve Row's Avatar
Steve Row
Al, Was this at Capitol? If so, they are just a little thick. After a run when I picked up my time slip, I was told they wanted to see me over at tech. I went over and this women asked if I had a driveshft loop. I said no, I don't need one since the entire driveshaft is inside a tube. She says, really? I went on to explain about the transmission in the rear of the car, etc. Then she says that she has a C5!!!
DOH!!
Old Sep 21, 2001 | 04:32 PM
MDT's Avatar
MDT
Default Re: Does the Vette Need a Drive Shaft Loop? (Steve Row)
Steve,
Doesn't sound like she has spent much time under her C5, huh? :D
Good luck.
Mark
Old Sep 21, 2001 | 04:45 PM
chuckster's Avatar
chuckster
Dude, your signature need explaining...
You have Intake, Exhaust and TPIS headers but you only show 311hp
And...You ran in the 12's
Tell me that Dyno number is old. The mods you list will give you 12's but 311 hp probably would not unless it was dropped from a cliff :D
Next time tell the track dude you have a Torque Tube. No driveshaft.
Old Sep 21, 2001 | 10:18 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
The C-5 DOES have a drive shaft,it is in the drive tube...It is supported within the drive tube with a front and rear bearing...Highly unlikely it will ever come through the tube :D
[Modified by C-5 TECH, 9:22 PM 9/21/2001]
Old Sep 21, 2001 | 11:45 PM
66ImpalaLT1's Avatar
66ImpalaLT1
Default Re: Does the Vette Need a Drive Shaft Loop? (C-5 TECH)
NHRA regulations specify the loop must be a certain distance from the front u-joint. Since it has no u-joints C5's must be exempt from the rule! :D
Eric :D
Old Sep 21, 2001 | 11:46 PM
TLewis4095's Avatar
TLewis4095
Probably safer than the average loop. They need to hassel the 5.0 mustang crowd. I've seen far to many of these built up w/mods and still have the 4-lug rear hubs & no drive shaft loop. Scary when the rearend locks up because they threw a shaft. :eek:
Old Sep 22, 2001 | 11:44 AM
Als98C5's Avatar
Als98C5
Default Re: Does the Vette Need a Drive Shaft Loop? (chuckster)
HI Chuckster,
Yes, I thought the dyno was a bit low for the mods I have, but it did dyno at 311rwhp. Took it to the track last night and ran 12.93 and 12.88 with the 18" BFG run flats. The 12.57 was on the 17" Drag radials I use at the track. I didn't feel like messing with them last night and was pleasently surprised with the two 12's
Old Sep 22, 2001 | 10:23 PM
Mag Red Monster's Avatar
Mag Red Monster
Elite Member
Cruise-In IV Veteran
Chuckster, I only Dynoed 308 and I'm in the mid 12's :D
Old Sep 23, 2001 | 12:02 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Default Re: Does the Vette Need a Drive Shaft Loop? (Mag Red Monster)
Someone once posted that we could be required to have a loop around each rear axle, to prevent them from digging in if they broke. Seems pretty unlikely to me, does anyone know different?
Old Sep 23, 2001 | 12:52 AM
chuckster's Avatar
chuckster
308 :eek:
Well it sounds like Dynos lie. I doubt a real 308hp can reach mid 12's :confused:
Probably more like 330 is needed...
Old Sep 23, 2001 | 09:04 AM
Mag Red Monster
Elite Member
Chuckster,
This dyno run was done at Lingenfelter's Shop........so I would say it was accurate. :rolleyes: Maybe he shorted every one's numbers inorder to entice us to order his turbo package :jester Joking Actually I can't explain it.....just a combination of traction and great driving! :lol:
To Does the Vette Need a Drive Shaft Loop?
