Service Column Lock & Pull Key, Wait 10 Sec
Old Nov 10, 2006 | 12:45 PM
5W0P3's Avatar
5W0P3
Default Service Column Lock & Pull Key, Wait 10 Sec
Ok, whats the deal? My car has the recall performed to fix this. Why am i getting this message?!
and it wont drive... it will idle but as soon as you put it in gear and start to move, it dies.
Old Nov 10, 2006 | 01:01 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
lol
http://forums.corvetteforum.com/show....php?t=1015483
Old Nov 10, 2006 | 01:04 PM
5W0P3's Avatar
5W0P3
Originally Posted by Ikester
Q I still get the "Pull Key and Wait 10 Seconds" message and "Service Steering Column Lock" message? What do I do now?
A1 Sometimes the latching relay in the CLB can get out of sync sending the wrong status to your BCM. This has happened to a few folks even with the CLB installed. The CLB latching relay gets out of sync with the BCM possibly due to shock, vibration or relay contact bounce during switching which confused the BCM. The CLB does not physically know which state it should be in; it only switches from one state to the other when it receives a signal from the BCM. The BCM can be reset by pulling Fuse 23 and waiting 10 seconds.
A2 Check to make sure Fuse 25 in passenger footwell is good.
A3 Verify the black wire to your ECL or CLB is grounded (zero ohms resistance).
A5 Verify the green wire to the ECL or CLB is shorted to ground while in the "UNLOCKED" position and +12Vdc while in the "LOCKED" position.
A6 If you get the "Pull Key and Wait 10 Seconds" message but no "Service Column Lock" message, it could be your security system and related to your key pellet.
Fixed
Old Nov 10, 2006 | 02:25 PM
5W0P3's Avatar
5W0P3
ok, so now it will idle, but when you try to move it, it dies.
Old Nov 10, 2006 | 03:16 PM
C17driver's Avatar
C17driver
if your column is locked, just take the key out and turn the wheel to the left and right really hard a few times then try to start the car back up. My column locked a couple of times and when I tried to moved it died. I had to unlock the column for it to run. This little tricked has worked both times my column has locked but I went ahead and bought the Column Lock Bypass so I will not have that problem again. Good Luck
Old Nov 10, 2006 | 03:23 PM
5W0P3's Avatar
5W0P3
I wish. Unfortunately, i have the CLB. My steering wheel turns, car starts and idles, but wont go over 2mph. I was doing this...
http://forums.corvetteforum.com/show...um_id=1&arch=1
yesterday, but i only messed with those 4 wires... nothign else. I'm going to try unlplugging and plugging my my CLB back in.
All my fuses are good.
Old Nov 10, 2006 | 04:01 PM
5W0P3's Avatar
5W0P3
http://97vette.com/howto/columnlock/bypasstest.html
I noticed on this page, he says "you should not hear the column locking" Why is it that I hear mine lock still? I have the CLB
To Service Column Lock & Pull Key, Wait 10 Sec
