Need Help With High Oil Pressure Reading
Old Nov 12, 2006 | 03:24 PM
Snake Slayer's Avatar
Snake Slayer
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Default Need Help With High Oil Pressure Reading
My oil pressure guage is pegged at 117lbs. Is the sensor bad or is it the pump ?
Old Nov 12, 2006 | 03:28 PM
Sick Z06's Avatar
Sick Z06
Does it stay at 117 when the car is warmed up? Does it do the sweep ok?
If yes to bth, more then likely sensor or wiring issue.
Old Nov 12, 2006 | 03:30 PM
TYSON1997's Avatar
TYSON1997
c5's are horrible with oil pressure sensor's. Ive been through 3 now and im done buying them. They are a pita to change and make sure you dont overtorque I think its like 15 ftlbs but look it up.
Old Nov 12, 2006 | 04:01 PM
Snake Slayer
Cruise-In V Veteran
The Guage is pegged at 80 and the dic is reading 117. Even with the engine off it reads 83lbs
Old Nov 12, 2006 | 04:04 PM
Oldvetter's Avatar
Oldvetter
It is probably the sensor.
Old Nov 14, 2006 | 02:33 AM
David426's Avatar
David426
Its the oil pressure sending unit for sure.. There is no such thing as 83psi with the engine off.. This is probably the second most common problem with the C5... Column Lock being #1. Consider a NAPA auto parts sending unit. Most of the threads I have read on this show the GM part to be a failure in the near future... There are other brands too. Do your research first. The Dealership wants around $300.00 for the job. Most of it is labor.. Pain in the butt project
To Need Help With High Oil Pressure Reading
