LS2 402 Motor mount problem - help
Old Nov 12, 2006 | 05:56 PM
WKMCD's Avatar
WKMCD
Default LS2 402 Motor mount problem - help
PROBLEM SOLVED - THANKS
We're installing an SDPC LS2 402 in my 98 C5. I remember reading somewhere that you may have to grind the motor mount to get them to align. I can't find that information now that we need it.
Has anyone run into this and can you tell me where you need to grind to get them to line up.
Thanks, we're getting really close on this.
Old Nov 12, 2006 | 07:31 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Hmmm... the part of the motor mount that goes into the cradle has a tab on it as does the part that goes to the aluminum part that physically bolts to the motor. Sorry, I don't know the official names of each of those parts.
But just as a guess, are they saying you need to grind the tabs off? That will allow greater flexibility in where the motor sits relative to the cradle.
Old Nov 12, 2006 | 08:07 PM
99blackFRC's Avatar
99blackFRC
I thought i read that it was already in the car. At any rate, yeah, I believe we had to grind off those pins for our LS7 swap as well. no biggie..
Old Nov 13, 2006 | 08:50 AM
see5's Avatar
see5
Hard to explain. If try and mount the mount to the block before you lower engine onto the bolts it is a quick fix. You just need to take a corner off.
Old Nov 13, 2006 | 09:16 AM
WKMCD's Avatar
WKMCD
Problem solved last night..Thanks
Old Nov 13, 2006 | 03:24 PM
Jackal's Avatar
Jackal
Pics of the fix?
Old Nov 13, 2006 | 10:19 PM
dads01dream's Avatar
dads01dream
To LS2 402 Motor mount problem - help
