Short Vs. Long Block
Old Nov 13, 2006 | 01:50 PM
dperretti1's Avatar
dperretti1
Default Short Vs. Long Block
I know this might sound like a stuid question but, I have a 2003 A4 is it a short or long block and are they interchangable.
I'm looking to do a direct replacement to a 427, but don't know which to pick. It is my everyday ride.
Old Nov 13, 2006 | 01:53 PM
robvuk's Avatar
robvuk
Shortblock and Longblock refers to the level of completion. A shortblock has no heads, a longblock includes heads and maybe cam. It depends on what you need to buy. If you're replacing to a larger engine, you will need the longblock or even more likely, the complete crate motor.
Old Nov 13, 2006 | 01:58 PM
Blue02ws6's Avatar
Blue02ws6
I would just look at what was included in the longblock "package". You might want to get different heads, cam, intake, so it would probably be better to get the shortblock and piece together the rest needed for your longblock, but for the original question the above is correct, it just specifies how "complete" the motor is.
Old Nov 13, 2006 | 02:00 PM
kromberg's Avatar
kromberg
Not really. A longblock is fine if he wishes to reuse the components that are not included from his existing motor. Things like oil pan, intake, valve covers, etc are prefectly fine to reuse.
Keith
Old Nov 13, 2006 | 02:02 PM
Blue02ws6's Avatar
Blue02ws6
Keith
That would depend on what block they used to build the new motor from, a lot of LS1 parts will not swap over to LS2's, but if it is a 427 they more than likely would use a ls1/ls6 in which everything would swap over.
Old Nov 13, 2006 | 02:40 PM
robvuk's Avatar
robvuk
Correct. I was thinking if he's going from an LS1 or even an LS6 to an LS7, he wouldn't want the old heads.
Old Nov 13, 2006 | 03:09 PM
dperretti1's Avatar
dperretti1
Thanks, that help me alot in understanding what I am looking at when I am ready go to do it.
I would probaly go for a turn key swap, any recommendations for some to use in Southern Cal.
To Short Vs. Long Block
