I have a stock C5 that starts up any idles really good but when you attempt to drive it displays ENGINE REDUCED POWER/SERVICE TCS" and the car idles really rough and sometimes stalls.Any ideas?The car throws the tps code but it has been replaced.I also changed the battery,cleaned out the grounding points and changed the TAC.My next move is the gas pedal and if that dosn't work then the throttle body.
No air leaks,the wiring harness was one of the first things that was checked pryior to buying any parts.Can't remember exactly which codes it was throwing but after looking them up one was for the TPS and the other was for the TCS inhibited by the PCM due to TPS.Thanks.
Had the same exact issue - replaced the gas pedal [thanks Gene at Karshop] and no problem since.
Replaced tha gas pedal and it worked fine for about 3 miles then back to square one. I guess I should just bite the bullet and replace the throttle body.
