Deeper transmission pans...
Old Nov 13, 2006 | 08:25 PM
blown in n.c.'s Avatar
blown in n.c.
Default Deeper transmission pans...
Anybody using one of these with an after market 3" xpipe and midsection before the cat back? Does it clear? Do you have any ground clearance problems?
I have seen the following brands for teh 4l60e--Hughs, Summit, milodon. Each claims to hold an extra 2 quarts and are made of the same cast aluminum.
Any feedback is helpful.
Old Nov 13, 2006 | 11:50 PM
Rag-Top Rick's Avatar
Rag-Top Rick
I can only comment on the B&M deep-pan.
Yes, I did/do have dome rubbing on the pass side where my B&B Bullet bolts to the Random Tech x-pipe.
For the time being I made a spacer out of pcv (with a metal sleeve inside it to prevent collapse) and used a hose clamp to seceure it inbetween the pan and exhaust.
I`m not sure what I`m going to do long term.
Old Nov 14, 2006 | 07:50 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Here is the install and mod of my 4 qt deep pan to clear my 2 1/2 " exhaust on the 00' coupe....
http://forums.corvetteforum.com/show...light=deep+pan
I will also be installing my rebuilt Rossler A4 in the 97' with a........hum............deep pan........to clear the T-brake and I already run 3" stainless works all the way back...............exhaust mods will be in order for sure
To Deeper transmission pans...
