TPS or APP Signal
Old Nov 14, 2006 | 02:44 PM
z0quick's Avatar
z0quick
Default TPS or APP Signal
I have an electronic TPS switch that is adjustable to activate between 0-5v.
-Is there a TPS signal off the PCM?
-Or have any of you just referenced it right off the TPS sensor at the throttle body?
-Or have any of you just referenced it right off the APPS (Accelerator Pedal Position Sensor) located right on top of the gas pedal? Prob here is that it only reads a small window of Voltage, maybe .8v - 2.1v
