Anyone running low boost on 11:1 compression?
Old Nov 17, 2006 | 10:37 AM
SCannon's Avatar
SCannon
Default Anyone running low boost on 11:1 compression?
402, .052 Gaskets, -4 dish pistons, 65 cc heads, comes out to 11.17:1, all top of the line parts. I only run at 22 degrees of timing.
I want to remove my nitrous and run 5 lbs or less boost with a Procharger. I would be having my car tuned for it. I also heard that boost can help my daily driving issues.
Old Nov 19, 2006 | 02:40 AM
z0quick's Avatar
z0quick
The nitrous is going to work much better for you with that high compression. However, you should be able to get away with 5psi, providing you have a properly cooled intake. Your timing will need to come down some to make this happen.
Help daily driving issues? What issues? I dont think it will 'help' dd'ing
