Running to hot??
Mark
Bill
In traffic or at a long stop light it is common to see the coolant temp rise to the area of 230 degrees (especially on a hot day) at which point the radiator fans will kick in to improve air flow through the radiator.
Modern engines are designed to run "hot" as it improves fuel econonmy and helps them meet emission targets. A "cold" engine is a heat sink that is robbing power from the burned fuel. Heat taken to heat the engine is wasted power.
I suspect the lack of a radiator shroud (I'm assuming you're referring to the seal around the radiator and A/C condenser) is your biggest problem. The Service Manual states :
"The cooling system uses deflectors, air baffles, and air seals to increase system cooling. Deflectors are installed under the vehicle to redirect airflow beneath the vehicle to flow through the radiator to increase cooling. Air baffles are also used to direct airflow into the radiator to increase cooling. Air seals prevent air from bypassing the radiator and A/C condenser. Air seals also prevent recirculation of the air for better hot weather cooling and A/C condenser performance."
A lower temp thermostat does NOTHING except increase the time (by a few minutes) it takes the engine to come up to "normal" temperature. A 160 degree thermo opens sooner than 195 thermo, but in both cases the engine will eventually reach the same operating temperature.
If you've removed the air seal, having the fans come on earlier probably won't help a lot as they'll be recirculating warmed air through the radiator. I'd bet the Chevy engineers spent a lot of time working out how to get the cooling system to work well given the body design of the C5, especially the nose area. I'd recommend you consider putting back whatever "shroud" or other components of the system you've removed. I strongly suspect you'll find your cooling system will work properly after that.
