C6Z Brakes
Old Nov 17, 2006 | 03:10 PM
The New Black's Avatar
The New Black
Default C6Z Brakes
Will the rears fit under stock C5 rims?
Old Nov 17, 2006 | 03:24 PM
QKSLVR Z's Avatar
QKSLVR Z
Active Streak: 90 Days
no
Old Nov 17, 2006 | 04:10 PM
The New Black
I thought I remembered someone running the new brakes on a C5 and they moved the rears to the front and bought another set of rear rims and added a spacer for rear. Guess not.
Old Nov 17, 2006 | 08:39 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
you can move C5 brakes to the rear on a C5
Old Nov 17, 2006 | 08:47 PM
BlackZ06's Avatar
BlackZ06
Why would you want to put C6 brakes on a C5?
Stock C5 brakes can easily lock the wheels (unless you're running ENORMOUS race compound tires) so what benefit do you expect to see? Try a more aggressive brake pad with the stock C5 calipers and you'll get more stopping power than your tires can possibly handle.
Old Nov 17, 2006 | 10:19 PM
QKSLVR Z's Avatar
QKSLVR Z
my cousin did that.. he used the stock rear 18x9.5" polished wheels on the front with a 1/4" spacer.. the rears were a rare set of aftermarket 18x10.5". hope this helps..
Old Nov 17, 2006 | 10:33 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
they look
Old Nov 23, 2006 | 08:52 PM
The New Black
Was your cousin one of the first guys to run the C6Z brakes on his C5? I think that was the post I remember reading.
Old Nov 23, 2006 | 09:22 PM
99 vett babycar's Avatar
99 vett babycar
What kind of question is this ?? You are far too reasonable
This is America man, BIGGER IS ALWAYS BETTER, NEWER IS ALWAY BETTER. Are you some kind of subversive or what ? If it's on the C6 we WILL find a way to screw it onto a C5- shift *****, tires ,wheels, brakes , shocks, seats, heads, wipers, valve stem end caps - you get it now ?? It's a rare form of ***** envy, limited to the most part to Corvette owners.. How could you POSSIBLY suggest STOCK parts - we can engineer this car a lot better than GM engineers.
Old Nov 23, 2006 | 09:42 PM
DanTTVette's Avatar
DanTTVette
Ahhhh, we are unmasked....
What do those GM guys know....
although now that you mention it,
I'm pretty sure I could have done a better job on the steering lock
Old Nov 23, 2006 | 09:53 PM
vetpet's Avatar
vetpet
Are you saying that you can put the front C5 calipers on the rear of a C5? What do you need to do this? It would probably give the brakes a bit more bite and the calipers would look a lot better than the dinky things GM put on the back.
Old Nov 23, 2006 | 11:20 PM
jdmvette's Avatar
jdmvette
Night Owl for life
http://forums.corvetteforum.com/showthread.php?t=953735
Old Nov 24, 2006 | 04:55 AM
morfi's Avatar
morfi
Not in a million years!
After a long time searching in the internet, I can say that there are a few wheel sets that could clear the C6 big brakes without spacers.
The most affordable wheel set is the Z07 from Corvette Garage (18x9.5, 53mm Front and 19x11, 63mm Rear).
If money is not an issue HRE wheels can clear the brakes for sure, BUT their prices are HOT!!
There are also some wheels in the CCW (Complete Custom Wheels) that could clear the calipers and there is a variety of wheels to choose from.
In any case, if someone decide to purchase the C6 brake kit, he should first try to find an aftermarket wheel set that could clear the breaks, with or without spacers installed and contact the dealer just to ensure that.
Take a look in my thread for more information.
http://forums.corvetteforum.com/show....php?t=1536735
C5Forever I am sure that you will find what you are looking for in here.
The guys in this forum helped me get out of a great mess!
P.S. Excuse my english....I am from Greece.
Old Nov 24, 2006 | 03:03 PM
The New Black
I'm sure I will, I just keep going back and forth on rims. Either I find one that loses a lot of lip with a BBK or I find one that clears that I don't like as much. Either way, my brakes are getting bad and it's time to upgrade.
Old Nov 24, 2006 | 04:00 PM
tiojames's Avatar
tiojames
Besides looking good they will fade a lot less than smaller brakes, and a lot of us do run bigger tires.
Old Nov 24, 2006 | 04:28 PM
QKSLVR Z's Avatar
QKSLVR Z
yes.. my cousin and i were the first to do this conversion
To C6Z Brakes
