Underhood electrical center
Old Nov 17, 2006 | 11:06 PM
CaliforniaJack's Avatar
CaliforniaJack
Default Underhood electrical center
My radiator fan stopped working and I traced the problem to a break in the wire from the underhood electrical center (the fuse/relay box in front of the battery) to the left fan. I want to remove the wire harness and fix GM's quality problem. How do you remove/disconnect the wiring harness from the bottom of the underhood electrical center??
