This site is great, thanks for all the help I have recieved thus far.
I ran the Diagnostics for a Service Vehicle caution the other day and came up with several codes, some reset and stayed out, but there were some sticky. None of them I can figure out to fix.
HVAC
B 0363H HVAC Actuator Feedback Curcuit
LDCM and RDCM came up with the following codes.
2282 through 2285 for the left and the right
Battery 1 and Battery 2 Voltage out of range
U1046H Lost comm
PCM
0522 Engine oil pressure sensor curcuit low. I imagine this code still comes up because of the oil pressure sensor that I still need to change.
If i unhook my battery for something and then hook it back up mine will throw a bunch of codes. I just clear them out and usually they never come back.
I did that at one point, probably will again. But I am concerned with the LDCM and RDCM codes, they just seemed odd. And the HVAC code concerns me as well.
when I first got my vette I think it had every code that was possible. I was totally new to the corvette world so I had no idea what to do. A guy on this forum told me to clean ALL my grounds on the frame. After that I had no codes at all. I think that is where I would start.
But thanks though.
LDCM and RDCM are for the Left Door Control Module and Right Door Control Module, unless your having problems with either door window, lock or position indicating I wouldn't worry about them to much.
