Homemade tool #J41760
Old Sep 23, 2001 | 10:36 AM
duosy's Avatar
duosy
Default Homemade tool #J41760
Yesterday I had to reprogram my tire pressure sensors. A Kent-Moore tool
#J41760 was required. This is a big magnet that GM probably sells for big $.
Local hardware store has a "General" #376C shallow pot magnet that did the
job. This is a permanent ceramic magnet that has a 35# pull. Magnet is contained in a 2 1/2" diameter X 3/8" thick steel shell with a 9/32" hole in the
center. Drill out the hole to 1/2" so the magnet fits over the valve stems.
Magnet stays in place due to the pull of the iron brake components.
Cost = $5.
Old Sep 23, 2001 | 10:39 AM
RPO_Z06's Avatar
RPO_Z06
Cruise-In III Veteran
St. Jude Contributor
Default Re: Homemade tool #J41760 (duosy)
Good info. :cheers:
Old Sep 23, 2001 | 12:26 PM
nevrenuf's Avatar
nevrenuf
LS1Edit Guru
Cruise-In I Veteran
Cruise-In II Veteran
I just use a simple "magnetic part retriever" . Costs about $3 and works fine..
Old Sep 23, 2001 | 03:45 PM
MDT's Avatar
MDT
duosy,
Thanks. Other members have reported using an old speaker magnet for reprogramming.
You're right...any tool associated with $Kent Moore$ is high dollar. :D :yesnod:
Good luck.
Mark
Old Sep 24, 2001 | 01:56 AM
Bill Dearborn's Avatar
Bill Dearborn
Default Re: Homemade tool #J41760 (MDT)
I got a magnet at Radio Shack for 99 cents.
Bill
Old Sep 24, 2001 | 12:25 PM
DUKE's Avatar
DUKE
Default Re: Homemade tool #J41760 (Bill Dearborn)
I have yet been able to re program the sensors....I think its the magnet that I have that is not strong enough. Going to get a parts retriever magnet at home depot and try.
Old Sep 24, 2001 | 12:38 PM
RedLandRocket's Avatar
RedLandRocket
Default Re: Homemade tool #J41760 (DUKE)
I went with Radio Shack but i used 2 magnets @ $1.98 plus tax.
Works great.
To Homemade tool #J41760
