Need Help with Code's
Old Nov 21, 2006 | 10:53 AM
Dans97's Avatar
Dans97
Default Need Help with Code's
So recently my Check Engine light came on. I pulled the following code's off the DIC : 10PCM - 6 Codes
80 Radio - 1 Code
99HVAC - 1 Code
BO-RFA - 1 Code
Is there a website I can plug these into to diagnose the problem ?
Thanks,
Dan
Old Nov 21, 2006 | 11:19 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
80 Radio - 1 Code
99HVAC - 1 Code
BO-RFA - 1 Code
The PCM codes are the only ones that would turn on your CEL. You need to extract the actual codes, then you can start to troubleshoot. Once the DIC displays "manual diagnostics," you may select a particular module by pressing the "options" button to go forward or the "trip" button to go back (10PCM would be 1st). Once a system is selected and a DTC is displayed, if more than one are present; press "gages" to move forward or "fuel" to go back.
Start here:
http://www.stengel.net/diccodes.htm
http://myweb.accessus.net/~090/dtcobd2.html
Old Nov 21, 2006 | 01:03 PM
Dans97's Avatar
Dans97
Thank's Im going to give that a try.
Old Dec 13, 2006 | 03:01 PM
Dans97's Avatar
Dans97
Here's the updates with the specific code's :
10PCM : P0134 H C -- Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 1
P1153 C -- Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 2 Sensor 1
P0135 H C -- Heated Oxygen Sensor (HO2S) Heater Circuit Bank 1 Sensor 1
P0154 H C -- Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 1
P0522 H C -- Engine Oil Pressure Sensor Circuit Low Voltage
P1431 H -- Fuel Level Sensor 2 Circuit Performance
80 RADIO : U1016 H -- NOT FOUND
99HVAV : B0363 H C -- Left Actuator Feedback Open
A0-LDCM : B2264 H -- Vertical Position Sensor Fault
A1 - RCDM : B2265 H -- Horizontal Position Sensor Fault
My interpretation is that I need a new 02 Sensors !! other than that the Left actuator Feedback Open leaves me clueless.
Any thought's ??
Old Dec 13, 2006 | 06:30 PM
dpd's Avatar
dpd
first,ignore all the codes with "h" for the time being.
for the o2 faults,i would check the fuse for the o2 sensors first.sounds like it's blown.if it is,see if any of the sensor harnesses are laying on the headers.chances of both o2's being bad up front,possible,but unlikely.
i'm assuming the car has oil pressure.if so.have you had a battery leak acid? the oil pressure sensor is wired to the pcm and goes across the class 2 line to the cluster.check to see if the wiring to the pcm is ok.if it is,you most likely either have a bad connection or a bad sensor.usually when the sensor goes bad,the oil pressure gauge reads 180 psi.
the hvac fault is either a broken wire or a bad actuator[hvac controller is not seeing the potntiometer.
the "h"faults are history[not present].
clear all the faults out and see what comes back.
To Need Help with Code's
