Headlight Problem, Help
Old Nov 21, 2006 | 10:11 PM
AmIBadd's Avatar
AmIBadd
Default Headlight Problem, Help
Has anyone had the problem with there head lights coming up and on when you start your car and will only go down when you turn the engine off? I have no control of them with the switch.
Old Nov 21, 2006 | 11:44 PM
JC in XTC5's Avatar
JC in XTC5
Do you have the Twilight Sentinal Option? That would control the headlights independent of the switch. And if the photocell on the top of the dash goes bad it could be seen as a dark condition causing the system to turn the lights on.
You should be able to disable that option via the DIC.
Old Nov 21, 2006 | 11:52 PM
AmIBadd's Avatar
AmIBadd
No, I don`t have that option.
Old Nov 24, 2006 | 01:32 PM
AmIBadd's Avatar
AmIBadd
ttt
To Headlight Problem, Help
