Transgo shift kit
Old Sep 23, 2001 | 10:42 PM
Rogerc5's Avatar
Rogerc5
Default Transgo shift kit
Has anybody installed a Transgo shift kit in their '01 A4?? If so what level and how hard was the install.
Thanks,
Rogerc5
Roger
Old Sep 23, 2001 | 11:50 PM
goldman's Avatar
goldman
Default Re: Transgo shift kit (Rogerc5)
Do these kits do anything that Powerloader doesn't do ???
Powerloader firms the shifts & adjusts the shift points nicely (as well as fan temps & other performance gains), with a 5 minute install.
Old Sep 24, 2001 | 08:27 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Roger....I've seen at least a couple people here that have them, hopefully they'll chime in :cheers:
Old Sep 24, 2001 | 12:37 PM
SilverStar's Avatar
SilverStar
Programming only increases line pressure.
I have the junior Transgo kit that has no adjustments. I have been told that the kit you refer to is for pre '99 cars. There is a potential for conflicts with the torque management program (although some have had good success).
Old Sep 25, 2001 | 02:57 PM
pmw94's Avatar
pmw94
Had a pro install mine for street&strip mode, which is one below full race. It shifts hard between 1&2, 2&3. When you operate manualy it shifts like a m6 but it is lazy downshifting in the automode unless you realy hammer it Cost $180 to install - car is more responsive and fun to drive.
Old Sep 25, 2001 | 05:14 PM
Jim Kramer's Avatar
Jim Kramer
Roger,
I was told by a local reputable tranny guy that the 01 A4's will not take a shift kit... due to the aformentioned Torque Management Program.
-Jim
Old Sep 26, 2001 | 08:01 AM
SilverStar's Avatar
SilverStar
Default Re: Transgo shift kit (VetteMan2k1)
I have also heard that the Powerloader will (may?) disable torque management. Check With Steve Cole on that point or one of the vendors. My junior kit shifts harder than stock at WOT. I am satisfied with it. It adds stronger springs and we swapped out the plastic pistons with aluminum ones (can you believe they used plastic in a 50K car).
To Transgo shift kit
