Code question
Old Nov 24, 2006 | 03:55 PM
C52000C5's Avatar
C52000C5
Default Code question
Anyone know what the hell this is?
P0430 TWC System Low Efficiency Bank 2-A
Old Nov 24, 2006 | 04:02 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
O2 Sensor
Old Nov 24, 2006 | 04:04 PM
C52000C5's Avatar
C52000C5
I'm guessing the rear O2's? Just put on LT's, gonna have to get them tuned out...Thanks
Old Nov 24, 2006 | 05:32 PM
dpd's Avatar
dpd
it's not a 02 fault or problem.your fault is for insufficent secondary air on bank 2[right side.the front o2's are what monitor this,so obviously they are working.
either the check valve in the back of the intake took a dump,you have a leak somewhere or if you've eliminated secondary air,you need to have 420/430 tuned out.
Old Nov 24, 2006 | 06:47 PM
C52000C5's Avatar
C52000C5
So it could possibly be a leak?
Old Nov 24, 2006 | 06:54 PM
dpd's Avatar
dpd
yea.with most headers you usually have to pull the intake and change the right side secondary air check valve and tube to the newer style[2001-up] to get the secondary air plate to the header the right way.
go back and retrace your steps,you probably have a leak somewhere
Old Nov 24, 2006 | 07:30 PM
C52000C5's Avatar
C52000C5
Is it possible to tune out the air system?
Old Nov 25, 2006 | 06:08 PM
C52000C5's Avatar
C52000C5
ttt
Old Nov 25, 2006 | 06:13 PM
dpd's Avatar
dpd
yea,but why not just fix it.if it worked before the headers went in and now it doesn't ,something is off or broken,JMO
Old Nov 25, 2006 | 07:47 PM
C52000C5's Avatar
C52000C5
I'm gonna take it to a lift and check if I can see anything. I'm just saying, if the air system itself is messed up, than it may be easier to just tune it out. Its not something I need to have working, or worry about not working
To Code question
