Fuel Door Release
Old Nov 25, 2006 | 09:34 AM
Fastshot's Avatar
Fastshot
8th Gear
Default Fuel Door Release
I have a C5 and the fuel door does not release from the console button. The fuse checks ok and I can release manually from the storage area. Anyone had this problem?
thanks,
fastshot
Old Nov 25, 2006 | 09:50 AM
MrEracer's Avatar
MrEracer
Have you had the radio bezel or center console apart lately? Like when installing a shifter. The fuel switch connector is on a short wiring harness and is often pulled out of the switch. It's located up under the center console and difficult to see and hard to get properly engaged. I lengthened the wires on mine in order to avoid this problem. Check to verify that this connector is properly engaged. You need to take the center console loose to do this.
Shirl Dickey
Old Nov 25, 2006 | 12:30 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Shirl Dickey
I've seen these come loose on their own also, slide the passenger seat as far forward as it will go and tilt the back forward then pull up on the E-brake and lift the center console up enough to see the connector, I'll bet it's disconnected.
Old Nov 26, 2006 | 11:57 AM
Fastshot's Avatar
Fastshot
8th Gear
Thanks guys, It was the wiring harness that had come loose. Perfect.
Now on to the next Corvette DIY adventure.
Old Nov 26, 2006 | 03:29 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Glad to hear you got it fixed.
To Fuel Door Release
