DTC Help
Old Nov 25, 2006 | 09:40 PM
fright88's Avatar
fright88
Default DTC Help
Ok so I just replaced my passenger side 02 sensor after replacing the headers with long tubes. Now I have the following codes
P0174 and P1153. Both codes are H C
Can anyone help me out here. Looks like the first has to do with the car running lean. Is this because te car needs a tune after the new long tubes? Is it safe to drive with it running lean?
The secon just says H02S insufficient switching. What coule be causing this?
Thanks for any help again.
Old Nov 25, 2006 | 10:09 PM
dpd's Avatar
dpd
your faults are for bank 2[right side] running lean and bank 2's front o2 sensor being lazy[insufficent switching].
o2 tight?
any exhaust leaks near or around the front sensor?
any leaks near secondary air?
o2 plugged in all the way?
Old Nov 25, 2006 | 10:14 PM
fright88's Avatar
fright88
We couldn't hear any leaks and there was no black marks around the clamps.
The 02 sensor is plugged in all the way. What is the secondary air?
Thanks for your help
To DTC Help
