Fluid Change On High Mile A4 = Problems?
Old Nov 25, 2006 | 10:59 PM
426 Hemi's Avatar
426 Hemi
Default Fluid Change On High Mile A4 = Problems?
Just bought a very nice 99K mile 98 coupe. Changed all fluids including the trans. Put about 60 miles on it and started having harsh 1-2 shifts. Shut it off then restarted---fine. Then on next trip noticed converter lock up acting funny. Set a P1870. There's a TSB that covers the whole scenario (01-07-30-023A/B), basically describing a worn bore in the valve body. Not 100% sure that's my problem---pulling the valve body tomorrow to confirm this, and to check out associated solenoids.
Anyhow my question to everyone here is if they have experienced problems after replacing very old fluid with new? My father has said for years that new fluid will dislodge sediments and varnishes that normally stay put and benign.
I'm thinking varnish took up the clearances in the worn valve bore -------and the new fluid flushed this away?
Old Nov 26, 2006 | 12:04 AM
CMYC4GO's Avatar
CMYC4GO
I think there is some truth to your father's analogy. We had an old beat to crap Grand Am that we couldn't kill for love or money. I used it for a work car. That beater had nearly 200K on the clock, the tranny had never been touched, and it shifted flawlessly. I decided to service the transmission to try to get a few more miles out of it. The transmission fluid looked like mud in that thing...it was nasty. After a full transmission service, within two weeks, the transmission went south on me.
Old Nov 26, 2006 | 12:58 AM
Mike Mercury's Avatar
Mike Mercury
how many quarts of tranny fluid did you put back in after draining ?
was the engine running - or off during the refill ?
Old Nov 26, 2006 | 05:20 AM
mackvest's Avatar
mackvest
GM has a tech bulletin on that 1/2 shift problem they have a new updated valve body for your 1998 c5 up through 2000!!!!
Old Nov 26, 2006 | 06:42 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Servicing the A4 tranny has to be done in a specific manner, if not the fluid level won't be correct which will lead to shifting problems.
Old Nov 26, 2006 | 09:00 AM
Patches's Avatar
Patches
Email me at edbon@insightbb.com and I'll send you all the relevant procedures on servicing the A4 tranny, including swapping the valve body and pressure switch (if necessary).
Old Nov 26, 2006 | 09:47 AM
widewheel's Avatar
widewheel
It's vey important to follow the factory servicing procedures on the A4 or you won't put enough fluid back in.
Old Nov 26, 2006 | 09:59 AM
426 Hemi's Avatar
426 Hemi
Yeah, I followed the proceedure in the 98 shop manual. Boy that's a lot of fun with the thing running, on the hoist, warmed up and the fill/check hole a whopping 2" from the red hot exhaust.
Wish they would have used a conventional dipstick tube--going to an access panel behind the seat. I could deal with that.
Thanks for all the replies fellas!
To Fluid Change On High Mile A4 = Problems?
