Car Ramps
Old Nov 26, 2006 | 12:22 PM
98 C-5's Avatar
98 C-5
Default Car Ramps
What car ramps are available for the C-5 ? Has anyone ever used the Rhino car ramps?
Old Nov 26, 2006 | 12:44 PM
JC in XTC5's Avatar
JC in XTC5
I like many here have used Rhino Ramps. They are great for the C5, either to raise the front (drive up) or the rear (back up). They give you enough clearance for an oil change, etc.
Old Nov 26, 2006 | 12:47 PM
98 C-5's Avatar
98 C-5
Is there any clearance problems. if so what can I use?
Old Nov 26, 2006 | 01:46 PM
BanditDude's Avatar
BanditDude
The gray (low-profile) ramps will work better with a c5. The standard black ones will scrape the front air dam hard when driving on/off. There are several other designs available as well, including stepped/stacked 2x10s, that work well even for lowered cars. I have the black rhino ramps and made a copy of the wooden ones posted by member MikeMercury. I primarily use the black ramps for support once lifted. The wooden ones have more lift and a more gradual rise.
http://home.earthlink.net/~wcjansen/...st_install.jpg
P.S. - If you already have the black ramps, you could probably place another board ahead of them and avoid the scraping issues.
Old Nov 26, 2006 | 07:18 PM
98 C-5's Avatar
98 C-5
Thanks...We'll give it a try.
P.S How thick is the board in front of the ramps for the gray type?
Old Nov 26, 2006 | 08:56 PM
C5Dream2004's Avatar
C5Dream2004
Race ramps work the best, super long and I think only have a 10 or 11 degree slope. Bad news is very pricey 249.00 plus s/h for forum members.
Old Nov 26, 2006 | 08:58 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
The black rhino ramps are great, $19.99 from Pep Boys.
Old Nov 26, 2006 | 09:34 PM
RAMMAN's Avatar
RAMMAN
Pro Mechanic
St. Jude Donor '16 thru '26
I use the gray Rhino Ramps. There rated at 12000lbs so I can use them on my truck and suv with a lot of comfort factor also. No board needed on my ZO6.
Old Nov 26, 2006 | 09:41 PM
BanditDude's Avatar
BanditDude
I haven't used the gray ramps, but am under the impression that stock height cars can use them as-is without damage. Even if it does touch, the front air dam is meant to give a little.
Hopefully someone else will chime in...
Old Nov 27, 2006 | 01:28 PM
Vetteoholic's Avatar
Vetteoholic
Thats what I need! That would make my life alot easier!!
To Car Ramps
