How do I remove the Fog Light fuse?
Old Nov 26, 2006 | 01:31 PM
FletcherT76's Avatar
FletcherT76
Default How do I remove the Fog Light fuse?
Like I said - how do you remove the large grey fuse for the fog lights? I believe it's #39 off the top of my head, but I've never seen a fuse like this and it doesn't seem to want to come off. I've pulled pretty hard but it doesn't even act like it wants to come off so I'm guessing there must be a trick I'm not aware of.
Any help is greatly appreciated.
Thanks,
Trevor
Old Nov 28, 2006 | 01:47 PM
FletcherT76
ttt
Old Nov 28, 2006 | 03:06 PM
BlackZ06's Avatar
BlackZ06
Thanks,
Trevor
Sounds like you're trying to pull the Fog Lamp relay (which is relay #39). The fuse (according to the wiring diagram that I'm looking at) is Fuse #6 (10 AMP).
HTH
Old Nov 28, 2006 | 03:42 PM
FletcherT76
Ok, thanks. I'll check #6 to see if it's blown. My fog lights stopped working a few weeks ago so I figure it must be a fuse - or they both burnt out at the same time which I think would be a little coincedental.
Thanks BlackZ06!
To How do I remove the Fog Light fuse?
