C 5 intermittently overheats/
Old Nov 27, 2006 | 08:15 AM
Tom Gazdecki ("Doc")'s Avatar
1st Gear
Default C 5 intermittently overheats/
Anybody have experience with this problem: my 2003 anniversary intermittently overheats, even on the coldest of days. Not constant. Strong coolant odor in heat vents when this happens. Dealer absolutely been of no help. Is this a warped head?
Old Nov 27, 2006 | 11:18 AM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
What (if any) are the other symptoms? Steam in the exhaust? Loosing coolant? Have you had the motor apart? Water in the oil? Leaking onto the ground?
Old Nov 27, 2006 | 02:53 PM
Ducati749's Avatar
Ducati749
i had a similar problem, car when started from cold would go all the way to overheating very quickly...heater would not work either...I checked many things but after cleaning the ac lines the problem seemed to go away...I cant say this was the fix for sure since i had also checked the water pump and thermostat....And added new coolant...
Old Nov 27, 2006 | 08:53 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
What temps are seeing, both at idle stopped and while cruising?
Old Nov 28, 2006 | 11:55 AM
Brad@RevXtremeAutoSports's Avatar
If you are not losing coolant then could be a stuck thermostat????? I am sure others will chime in too with some ideas. Process of elimination. Start with the cheapest first.
Good Luck
Old Nov 28, 2006 | 01:35 PM
Architect's Avatar
Architect
Definitely sounds like a faulty thermostat.
To C 5 intermittently overheats/
