Rough Idle -- What to check first?
Old Nov 27, 2006 | 01:30 PM
2K4Vert's Avatar
2K4Vert
Default Rough Idle -- What to check first? -- SOLVED ;-)
On my way in to work this morning, commute is around 30 miles one-way, car (2004 Vert) was running fine. 25 miles into the commute, I hit my first traffic light and noticed the car was idling very rough. Any speed over idle, runs fine. If I put in park and bring up to 1,000 or so RPMs runs smooth.
Only performance mods are Blackwing intake and LG headers w/ hi-flow cats. Intake has been on a year or so, headers intalled 7/29. Been running fine. Checked for codes, there are no codes.
Any ideas on what to check? I did get gas Sunday at an out-of-town Chevron, but not my usual location. Could this be a symptom of bad gas?
Thanks...
Old Nov 27, 2006 | 01:42 PM
zeevette's Avatar
zeevette
First thing is spark plug wires, then since you have headers, O2 sensors.
Old Nov 27, 2006 | 01:46 PM
WKMCD's Avatar
WKMCD
Get some electrical cleaner and clean the inside of the MAF - gently.
My $.02
Old Nov 27, 2006 | 01:47 PM
ericdwong's Avatar
ericdwong
Vaccuum leaks, then make sure all the cylinders are firing. Like mentioned could be plugs too, but in my experience on a C5 bad plugs will idle OK but stumble under load at lower RPMs.
Old Nov 27, 2006 | 02:11 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
any codes? Check plug wires, 02 wires, MAF (clean it), and also check the passenger side fuel injectory wiring harness, there's a bracket at the back left of the intake manifold that can rub through it and make the car run poorly.
Old Nov 27, 2006 | 02:47 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
Look for intake leak AFTER the maf.
Old Nov 27, 2006 | 02:51 PM
2K4Vert's Avatar
2K4Vert
No codes...
Old Nov 27, 2006 | 03:30 PM
2K4Vert's Avatar
2K4Vert
Thanks for all of the replies!!
Went back to the car, started it up, and let it idle. Same rough idle problem after sitting since around 7:00am. Rough part still stops at around 1,000 RPMs.
Checked for codes, and still no codes. Main concern now is whether it will stall on me on my way home.
Old Nov 27, 2006 | 06:30 PM
jers98vet's Avatar
jers98vet
My $.02
You probably have some air filter oil getting through the filter and settling on your maf. Remove the maf and clean it with some maf cleaner or electrical contact cleaner.
Jer.
Old Nov 27, 2006 | 09:58 PM
2K4Vert's Avatar
2K4Vert
Jer.
I installed the Blackwing about a year ago, would the air filter oil problem appear this long after? Would the problem occur all of a sudden? The car was running great Thursday and now all of a sudden it barely idles.
I just returned from some pretty high rev (not exceeding the legal speed limit but not using overdrive either) driving. Car pulls and sounds great at around 3,000 RPMs. I did, however, notice a lot of hesitation getting up to speed on the Interstate entrance ramp from a stop.
I'm still thinking "bad gas", but I'll try the maf cleaning. What is the brand for the cleaner and where do I get it?
One more thing, anyone have a write-up on how to clean the MAF?
Still no codes...
Thanks...
Old Nov 27, 2006 | 11:37 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Check for burned plug wires, and also that the screw-on connector has not worked itself loose on one or more plugs.
Old Nov 29, 2006 | 04:28 PM
2K4Vert's Avatar
2K4Vert
First thing I checked was the spark plug wires. The second plug wire I checked had popped of the spark plug. Snapped it back on and woo hoo!!
On the way home last night, I bought some MAF cleaner. So, since I took the day off to work on the car and fixed it in 2 minutes, I cleaned the MAF. No sign of crud. That thing is a PITA to get unplugged!!
Thanks again for the suggestions!!
Old Nov 29, 2006 | 06:04 PM
jers98vet's Avatar
jers98vet
Glad you fixed it and that it was a simple fix.
Jer.
Old Nov 29, 2006 | 11:25 PM
2K4Vert's Avatar
2K4Vert
Jer.
Yup... In the past, before reading the great information on the forum, I would have taken it to the dealer hoping for warranty work. In this case, I probably would have paid $100 for a diagnostic analysis, and all they would have done was snap the plug wire back on!!
Old Nov 30, 2006 | 01:19 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
VR
To Rough Idle -- What to check first?
