changing tranny fluid
Old Dec 1, 2006 | 08:49 PM
tngerman1999's Avatar
tngerman1999
Default changing tranny fluid
in my C5 going with the mobil 1 synthetic need to know the fluid capasity of the transmission
thanks
Old Dec 1, 2006 | 08:50 PM
jbauch357's Avatar
jbauch357
have 4 qts handy and you will be fine - if you have a manual.
Old Dec 1, 2006 | 09:02 PM
Xlr8yourC5's Avatar
Xlr8yourC5
I had heard that the 97-00 6spds had paper based blocker rings and some synthetics would damage (react/swell? dunno) the paper -
(01 and up were carbon fiber rings IIRC)
I thought there were some old threads on this but don't remember which fuilds were reported to cause a problem.
Old Dec 1, 2006 | 09:11 PM
tngerman1999
mine is an automatic so I guess im ok?
but thanks for the info
Old Dec 1, 2006 | 09:38 PM
Xlr8yourC5's Avatar
Xlr8yourC5
Correct, I have a manual and wasn't thinking of the Auto.
Old Dec 1, 2006 | 09:40 PM
tngerman1999
Default differential
probably change differential also , what kind of fluid , and what capacity does it hold
sorry guys about stupid questions just dont have a owners manual and am new to the C5
Old Dec 1, 2006 | 09:59 PM
2KFRC5's Avatar
2KFRC5
Download: 1999 Corvette Owners Manual in .pdf
Old Dec 1, 2006 | 10:07 PM
Dirty Howie's Avatar
Dirty Howie
Are you dropping the pan and servicing the filter or are you trying to replace all the tranny fluid??
DH
Old Dec 1, 2006 | 10:12 PM
tngerman1999
dropping the pan (yes)
Old Dec 2, 2006 | 04:58 PM
tsts's Avatar
tsts
You do have the option of having all the fluid changed using GM's new Dexron VI - all synthetic. (all the dealerships do this, but you must watch/check them to make sure it's not the old Dexron III).
Old Dec 2, 2006 | 05:11 PM
jbauch357's Avatar
jbauch357
sorry wasn't paying attention when I replied the first time around...
If you have an automatic dropping the pan and replacing the filter then filling the system back up won't do you a lot of good. It will only replace approx 4 qts of fluid when the entire system runs 12-14 quarts. Take the car to a good service shop (not always the easiest thing to find) and have them hook the vehicle up to an automatic transmission fluid flushing machine (T-tech is the one I am familiar with). I have operated these machines many times, they work flawlessly and replace all the fluid in the system. The only drawback is this service can be pretty expensive due to the cost of the machine and the amount of fluid needed, running prices will probably be between 149 and 200 - or considerably more if you specify that you want synthetic fluid.
To changing tranny fluid
