won't go into 6th gear
Old Dec 3, 2006 | 08:55 AM
1RED1's Avatar
1RED1
Default won't go into 6th gear
I can't get it to shift back into 6th gear,down shifted to go though
toll, up shifted from 4th to 5th when i put it in 6th nothing happen
no grind no gear just like it was in neutral
shifts feels normal and shifts ok in all other gears
Old Dec 3, 2006 | 08:59 AM
blazeone's Avatar
blazeone
If you have an aftermarket shifter check to see if one of the stop bolts came loose and is jamming the shifter. It happened to me with a Hurst shifter.
Old Dec 3, 2006 | 09:04 AM
1RED1's Avatar
1RED1
stock shifter
Old Dec 3, 2006 | 09:23 AM
65GGvert's Avatar
65GGvert
I'm not familiar with the MN6, but on my 65 4 speed a nut came off the linkage rod that connected it to the shift lever on the side of the tranny and even though the rod moved the lever never did.
Old Dec 3, 2006 | 10:24 AM
Vetteoholic's Avatar
Vetteoholic
Get a Hurst, but obviously get the current shifter/linkage checked out by a pro 1st. Hope It's nothing major Best of luck & Happy Holdiays
To won't go into 6th gear
