Transmission downshifts under light load
Old Dec 4, 2006 | 04:30 PM
larrys98's Avatar
larrys98
2nd Gear
Default Transmission downshifts under light load
I have a 98 Vette automatic. While travelling between 35 and 50 mph at a constant speed on level road, the tramsmission shifts normally into OD. Then when the roadway drops off over a hill and the load lessens, the transmission shifts down a gear. This does not happen everytime but usually happens when the transmission is warmer than 170 F. The fluid levels have been checked and are fine and there are no leaks. Could this be a sensor? If so how would I check for this?
